Output Triggered on Switch Counter, How to?
Hkinkade
Calif
I want to trigger an output based on a counter. For example I want a drive port to be turned off after a momentary switch is activated N times. Can this be accomplished?
This is not supported natively in HYDROS right now. Counters cannot be used directly as a trigger condition for outputs. You would need an external controller or logic device to count presses and then send a single on or off signal to HYDROS. It may be possible in the future if logic rules are expanded by CoralVue, but today it cannot be done internally.
