Best way to extend DIY 0-10V dimmer cables without signal loss?
  • Thread starter Thread starter Munaz
Munaz
Canada
’m running a DIY 0-10V dimming setup for my Quanta Helix lights. The cable run I need is longer than the stock length. Has anyone successfully extended these cables without affecting signal accuracy? Any tips on wire gauge or connectors would be helpful.
I had to convert to a cable tht was already in place that was run between my garage and the tank around 35ft away. It was a 6 wire cable that was used for the bus cable on the Digital Aquatics controllers. My X4 is in the garage and the lighting was at the tank. My X4 controls my lights using the 0-10v outputs and the cables are over 35ft in length.
