Audible alarms being triggered without notification or email.
  • Thread starter Thread starter tree
tree
New Jersey
I’ve looked through the forums but haven’t found anything similar to what I’m experiencing.
My setup includes a Launch, XP8, and Minnow running together as a collective, all on the latest software. I keep getting a brief audible alarm (less than 30 seconds), but I can’t determine what’s triggering it and I do not getting any notifications or emails either.
I only have three inputs configured with red alerts—temperature, ATO overflow, and a display tank level sensor (as a backup to the ATO sensor)—and those are the only conditions set to notify me. Overall, my configuration is fairly simple.
What’s puzzling is that when the alarm goes off, everything appears normal. All inputs and outputs look fine during and after the alert, with no obvious indication of an issue.
Has anyone run into something like this or have suggestions on what I should be checking when the alarm triggers?
Try setting up an output an use the inputs one at a time on it. Use the generic output type but turn on enable advanced settings and set the minimum on time for several minutes. Also set the input mode active to the same condition that would teigger the alert. If you get alerts but the output log does not show the output coming on then set the input to another one of the inputs.
