burningedge
I'm trying to create a generic output and have a question about using a temperature range with the thermometer as an input. I can select a temperature low point and a temperature hi point. I'm confused about the function beneath those settings called "active when input 1" that I can toggle to select "temp low" or "temp hi." What do these mean? The language is confusing to me. Does active when "temp low" mean that the device will be on when the temperature is anything below the upper end of the range, i.e. essentially anything below the temperature HI point? Or does it mean that the device will be on when the temperature is anything below the lowest end of the range, i.e. essentially anything below the the temperature LOW point?
P.S. SUGGESTION: The toggle would be a lot clearer if it were "active when input 1" and you could select between: "above hi point," "below hi point," "below low point," or "between low and hi point"
