Raiden
Using this or potentially a DIY option - HYDROS Command Bus Cable (DATA Only) - HYDROS how far can things be split apart?
I haven't checked for sure, but I would probably want a 100' cable, would this be still good or serial signal would degrade too much?
My RO/DI system and an ATO container are fairly far apart, I used around 60-70 feet of PVC pipe to do a run from RO/DI barrel to ATO barrel, a more direct run of cable might be possible in 50, but maybe would have to be more.
I have Iwaki pump in garage that can push water from 55g barrel in the garage into a 30g barrel on the second floor that will be used for ATO. Pump is already on an XP8 outlet, I would just want to add two water level sensors to the ATO barrel to turn it on and off as it automatically would refill from garage RO/DI barrel. Also would want to auto mate RO/DI barrel refill, but that's simpler at least from distance perspective as collective of things is already there.
