Ill tag @Carlos but the best is to submit a ticket to support.coralvue.com and Carlos can help you better through that portal.I am having an issue updating the firmware to 190 from 152 on a new Control 2. It says the update failed with error 5379. I've tried three times with the same result.
Good to hear, still be good for Carlos to see that this happened. 152 was an older build so there could be a hidden issue going from such an old build to 190.Thanks Jeff. I rebooted the unit and the forth time it worked. Guess it was just one of those random things. Mods, you can close this thread.
