I was looking and trying to setup my return pumps to turn off when I turn on feed mode like I can with my power heads. The return pumps are connect with my xp8. Is this possible? Thanks
Make sure that output has the feed mode unchecked in the active when settings for the output. I do not use feed mode since I use an automatic feeder. So I use an output that is triggered by feeder output and has a minimum on time of 30 minutes which is how long I want the feed mode to last. All the outputs I want off during the feeding have this output in either their schedules or the outputs set in the depends on and use a dependency mode of off if on. With the schedules all non feed mode schedules use a dependency mode of off if on and the feed mode schedule is set to a dependency mode of off if off. I do not turn off my return for feed mode but do slow down my wave pumps to 6% using a feed mode schedule.
