What exactly are you trying to do? I cannot see an instance when an chiller and a heater could be on at the same time if each output is setup correctly. Fortunately I don't need a chiller but do use the chiller output type for cooling using the evaporative cooling method using fans. Below in the first 2 screenshots is one of my heater outputs the second one is the same except the turn on temp is set a little lower so both do not turn on at the same time. The last 2 screenshot are my cooling output settings.Assuming each output is only on under a specific condition, could this possibly create a 'doom loop'? ie heater and chiller (which is the case in question) but if a temperature variation/drift causes both to be off, neither would ever turn on?
