Mike.L.Angelo
I've had some discussions on Fb about my issues getting reagent here in Canada. I'm barely in Canada as it is which makes it even harder. .
I've learned from diving into some rabbit holes that the same concentration of hydrochloric acid can be used to produce the same results as the sulfuric which is what I believe is most commonly used.
I was able to get a bottle of HCI on Amazon of all places and I'm wanting to make sure I'm understanding everything correctly.
If I dilute to the ratio shown in the pic, I should end up the same as the concentrated reagent correct?
Then just dilute 4 to 1 and I'm good to go.
