BAMatter
Trying to dial in my Dynamic Dosing- example:
alk 10dkh low and 10.5dkh high
80ml at low point- schedule 24 doses at :03
3ml at high point
Last alk test concluded at 12:28 @ 10.36dkh
System dosed .9ml’s at 1:03
Does this amount seem correct? I kinda figured ballpark since 10.36 is about 75%, then 80/24=3.33 x .75 = 2.5, which is what I figured would be dosed.
I get a bit confused with the amount to dose at high. Is that just if the test is above the high, meaning it figures out anything 10.00-10.49dkh based off percentage of 80ml’s or does it take 80mls and whither down to 3ml split between 24 doses, and remain at 3ml split between doses anything higher than 10.49?
Sorry if confusing, just can’t seem to fine tune this in.
3ml at high point
