I am setting my tank up on a Kraken and am trying to get my return pump hooked up to the 24v force ports to have battery backup. I have a Sicce SDC 7.0 return pump which I confirmed on the power brick is a 24 volt. The issue I am having is that there are no barrel connectors on the pump controller. The only connections this pump has are some type of 4 pin connections.
The strange part is that I also have a Sicce SDC 3.0 which does connect to the controller via barrel connector which would work on the Kraken but the pump is not big enough for my tank.
Any suggestions on how I can get the Sicce 7.0 pump connected to the Kracken force port and do away with one more wall wort.
