I dove head first into Hydros nearly a year ago and purchased a lot of stuff, X10 being one of them. At the time there was a lot of hype about Maven & if I remember correctly, Maven will need an X10 or something to deliver the tank water/reagents for testing. I believe it would need 3 of the 4 heads on X10. I also have 3 Soles sitting here that I had planned to use for AWC and still can. What's the better way to go for dosing? Pick up another Sole & save the X10 for Maven? Or just use the X10? I dose Alk/Cal/Mg/Limewater.
Can Sole be powered by Kraken? I have Force Port to Power Port cables. It calls out on the tag several Hydros items it will power but it does not specifically call out Sole. See attached photo. I had a plan when I bought all of this but I just don't remember it all clearly.
Please see photo two. If I go with X10 for dosing, what is the best way to convert the X10 dose head connections over to push connect? Photo three are my dosing containers using push connect.
Thanks in advance for any advice.
