kenbennedy
I want to use 0-10V output #1 to send inputs to my ICDPC. I have successfully created an output signal trigger feed mode on the ICDPD when the Control 4 enters Feed Mode. That much works. I tried to create another output using 0-10V #1 to send 3V to the ICDPC, but it appears I cannot create a second output voltage using the black wire/0-10V #1. Is this true? I confirmed that the 3v and 5V outputs are only on mutually exclusive schedules and would not run at the same time, but that still did not allow me to do add another voltage out. The ICDPC only has one 0-10V input, so I cant use another cable. I want to use the one cable to send 0V, 3V and 5V at various times from the Control 4 to ICDPC. Is this possible? Do I have to fabricate a Y harness and combine two output cables?
As a last resort I could create matching schedules on both the Control and ICDPC, but I prefer to have the ICDPC follow the modes of the control.
Thanks for the help everyone.
