The quad cable is for connecting to either the 0-10v inputs or the 0-10v outputs and splits them i to four separate i puts or outputs using 3.5mm plugs. Neither can control lights directly. The 0-10v outputs can control LED fixtures that have a 0-10v input for control. You would have to check with the specific fixtures you want to use and see if they have a 0-10v control input or not. The 0-10v inputs and outputs are only on the X4 and WaveEngine at this time. I think the WaveEngine LE has 0-10v inputs but not outputs on it.
