derek_SR
My understanding is that the Sole (and other peri pumps) perform the “push” better than the “pull.”
I have my SW mixing station in the garage about 25ft away from the tank. I am running a collective inside under the tank - I was planning to install both Soles under the tank for AWC. They would replacing versa pumps.
But now I al considering putting the fresh SW sole in the garage so it’s “pushing” the 25ft distance. I figure both pumps might stay calibrated closer this way also.
However, I am not seeing any command bus cables long enough to reach the garage. Can I just power that pump standalone and leave it off the collective, programming it separately? Or must I connect it via command bus and run it under the tank with the other hydros stuff and live with the fact it will “pull” the 25ft distance?
Thanks for the help!
