When you generate an alert output, detail in the log what caused the alert. To make it easier to track down alarms. Instead of just off/on, put what causes it to turn on.
Most inputs do have alert settings for when they get out of range. If an output is getting triggered and has multiple inputs and I suspect a particular one I can setup an out using that particular input and set the minimum on time for the output for a few minutes so it is long enough to register in the log if do trigger.Hydros currently only logs alert outputs as ON/OFF, which makes tracking short or intermittent alarms hard. A useful improvement would be to log the actual trigger, like which sensor or input caused the alert, even if it’s too brief to trigger a notification. This would make troubleshooting and monitoring much easier.
If it is audible then it has to be an alert level that has audible turned on. Normally that would be a red alert. How many inputs or outputs have a red alert set for a alert level on your system?+1 for alert logging. Capturing what triggered an alert—and exactly when—is essential for future improvements.
At the moment, I’m dealing with a phantom error that sets off an audible alarm without any accompanying notification or email, which makes it difficult to diagnose and pretty frustrating. Adding an alerts log would provide much-needed visibility into what’s happening behind the scenes.
