Aurora V12 with Extension Question
CharlesS
Rancho Cucamonga ca
I am looking for some advice from current Hydros users.
I am currently looking into purchasing the Kraken, along with the Aurora V12 light with extension. As I am doing my research on the lights and extensions it states requires a new 180W power supply unit, basically a new brick to handle the 650 watts of power. My question before purchasing the Aurora V12 with extensions, will the Kraken be able to handle the power, plus run my skimmer pump, calcium recirc pump etc etc.
Charles
Charles
Forgot to add will the Kraken be able to handle the power, plus run my skimmer pump, calcium recirc pump etc etc. without having to purchase the additional PSU which is a brick and the Kraken was built to eliminate the bricks.
The Kraken Outputs are only the force ports which are 24v DC and drive ports which are 12v DC. On battery power the force ports only get 12v but that would only happen if you have a backup battery installed and there was a power outage. The specs for the force ports and drive ports are in the info for the Kraken on the CoralVue website.
