Hi Hydros Family,
I'm considering setting up an AWC system. Currently, I have an X4 and an XS controller in a collective with three wifi power strips. I already have an ATO setup but would like to add an AWC to the mix. As I understand it, I would need two additional pumps, two additional water level sensors (one for low water level in the sump and one for low water level in the saltwater reservoir), and some tubing to make this happen.
Here is what the setup would look like. The saltwater reservoir would be about 7 feet away from the display tank and sump. I would like to drain water out to my basement anout 25 feet down from the tank. Here are the details on what ports I have available on my collective
Used Inputs
2 x Temp sensors
1 x Skimmer sensor
1 x Water level sensor (high water level used for ATO setup)
1 x Water level sensor (in ATO reservoir)
1 x Leak detector
1 x PH Probe
Available inputs
2 Sense ports on my XS
Available outputs
1 drive port on my X4
2 outlet plugs on my wifi power strips
Needs (I think):
2 x pumps
2 x water level sensors
tubing
Thanks in advance for any feedback.
Used Inputs
2 x Temp sensors
1 x Skimmer sensor
1 x Leak detector
1 x PH Probe
Available inputs
Available outputs
Needs (I think):
2 x pumps
tubing
- So, the first question is, am I missing any equipment?
- The second question is, what kind of pumps should I use? I'm concerned about creating a siphon, especially for the pump that drains the sump as it will go to a lower level than my tank.
- Any other considerations?
