AWC - Using water level sensors to shut it off
kelpfly
California
I was hoping to use water level sensors in my AWC water reservoirs to disable the water change if the reservoirs are full or empty (i.e. the used water reservoir is full, the water level sensor prevents the pump from pumping more water in, the fresh saltwater reservoir is empty and the water level sensors prevents pump from trying to pump more in). Essentially, I'd like the system to not try to do more water changes if either reservoir is unprepared for it. Is this possible? I tried to set it up but wasn't sure how to figure it out. Thanks!
Setup an output that is dependent on the inputs being in the right state using the generic output. Set it to be on when it ok for the AWC to run. I have one I use for control of the AWC and one for the ATO like this. The first screenshot is the output for AWC control. My drain pumps to the kitchen sink drain so I did not need one for the drain container full but it can be easily added. The second screenshot is the depends on settings in the AWC output settings for mine.
