AWS Cloud Outage
Carlos
Administrator
Staff member
HYDROS Lab
Tuesday, May 3, 2022 @ 21:45
It looks like AWS is having issues affecting HYDROS Cloud connectivity.
- Your devices will be breathing yellow and sometimes red
- You will not have connectivity on the HYDROS app
- You will not be able to make any configuration changes while the cloud connection is down
- HYDROS will CONTINUE to work and communicate with other HYDROS devices and WiFi strips within your home network
- You can override outputs by switching the app to Read-Only mode (https://www.coralvuehydros.com/.../hydros.../read-only-mode/)
- HYDROS will CONTINUE to monitor inputs and perform actions by itself without the cloud as it keeps a copy of all configurations locally.
Tuesday, May 3, 2022 @ 22:26
Amazon got things fixed, and items are starting to come back to normal. The cloud service is back up. HYDROS devices will eventually reconnect but power them down and up again if you want to speed up the reconnect routine.
If the devices are ok, but your app is not connecting, try completely shutting down the app and starting it again.
