A calcium reactor is mainly about balancing pressures. It would help if you made sure that the pressure from the CO2 regulator matches the pressure inside the reactor chamber. When they do, the bubble rate is very steady and predictable. On the other hand, you either have a very slow or swift sporadic bubble count when the pressures are off.
The easiest way to achieve a balance is to maintain as many variables constant. For example, changing the recirculating pump or the flow will adjust the pressure inside the reactor and throw off the bubble rate. For that reason, we always recommend keeping the recirculating pump and the flow (in and out) the same and only turning the CO2 ON/OFF according to the Alkalinity level in your tank and the pH level inside the reactor.
If you want to reduce the effluent concentration, you raise the pH level inside the reactor. If you're going to increase the concentration, you lower the pH of the reactor. However, both bubble rate and effluent (outflow) remain constant.
The more variables you adjust, the harder it is to keep a reactor going, and unfortunately, that has been the trend for many years. Folks want full control of every part of the reactor when in reality, the best way to keep the reactor stable is by keeping the number of adjustments to a minimum.
It is easy to hit a target when stationary, and only the target is moving. However, it is much harder to shoot it if the target moves while moving up and down and running on an uneven trail.
