Calculated fields
christopher.issler
PA
I would like to see a way for multiple probes, PH for instance, to average the values of both probes, to use that averaged value for decision making. Average, Max, Min.
I have a large system, and I would like to use the PH of the tank, first floor sump, and basement (where the CA reactor is located) to determine if things like Ozone & CA reactors and lightning is turned on for the 250g algae tub. Just to help stability.
We do something like that with temperature probes regarding the Heater and Chiller outputs. You can define two sensors, and the system will use either one to control the heater or chiller elements.
I can add this to the wishlist, and if enough people request it, we could add something similar to outputs with probe inputs such as pH, ORP, or the upcoming conductivity.
Exactly. I have a ozonizer, lighting over a tub of cheato, calcium reactor, and would like to average out the levels of PH to determine to or to not turn on lighting on Cheato. If tank, sump, and sump 2 max of ORP is below set level.
Just another way to ensure safely.
