kd_howard
I have an XP8 and an X3 in my collective. How many controller may be added using a power/data cable before it is necessary to add another power supply and connect with a data only cable?
I have had as many as 5 hooked to the same power source before if you include the one that is giving the power, My guess is it would depend on what output ports are on those controllers and what kind of load those outputs had on them. I have an X4, XS and 2 X2 along with the controller that is the power giver so that adds up to 5. They are even in my garage where there is no heating or cooling so the temp can be between 40 to 110 depending on time of day and time of year. It has been setup like this well over a years. Below is a screenshot with the 4 controllers that draw power from the fifth controller. It show the buss current each are drawing from the buss at the time of the screenshot.I have an XP8 and an X3 in my collective. How many controller may be added using a power/data cable before it is necessary to add another power supply and connect with a data only cable?
Do not use any of the power packs that connect directly to a command buss connector if there is another power source since they have no isolation circuits in them. The XP8, Wave Engines and XD all have isolation circuits that prevent power from going back into the power supply. You only want it to flow from the power source and not back into it. If you need to use one of those supplies then make sure and use a data only cable between it and the other power sources.I did have the power supply for the X3 plugged in at one time and everything seemed okay. I think I remember reading somewhere that was a big no so when I moved my controllers over the weekend I did not use the X3 power.
No problem, glad to help.The veil has lifted! Thanks for the clear explanation and illustration. I really appreciate your help.
