Reefer350C
Hello I am trying to set up a 0-10V output from my Hydros controller with the 0-10v cable to control my icecap dual gyre WiFi controller... I've already read the article on the website on how to do it. Ive set up a variable light with a min:50% and max:51% setting made sure the output is set correctly on both units, but for some reason it still is not working. Ive reached out to Carlos and via email he thought the 3.5 mm jack wasn't pushed all the way in, so as per his recommendations i trimmed the plastic around the male jack. Still have not fixed anything... I've taken a multi meter to the jack and tested the output when switching from normal to feed mode. The output I get is nothing, but if I clicked the output on manually I get 10.2V DC, which then if I set the input voltage on the ICDPC to 10V I can manually turn feeding mode on... I was wondering if anyone else has had any problems setting up a 0-10V output? Also is there any other way to control the voltage output easier on the hydros controller? It would seem since it is a controller and a lot of reef tank equipment utilize the 0-10v inputs the hydros software would have a simple 0-10v output voltage selection you can set and mirror to your device input.
