Dates on graph wrong
KWolfe81
Issaquah, WA
I just added 0-10v GENERIC analog input. The input graph has the dates way off (for future posterity, today is Feb 20th):
Is there a way to erase all previous data and get the graph dates correct? Clearing the Local Cache and resetting the device didn't solve the issue.
FYI: The input was previously configured as a MODE input connected to different hardware.
Also: being able to change the grumpy-face icon would be great too. Sorry if that's an obvious setting somewhere I missed.
Use a different name to get a clean graph. If you just used it again it will take a while for it to populate the graph.
Fixed the grumpy icon at least.... Just to be clear, I made another INPUT using the same analog input that exhibits the same issue:
This is a brand new input name.
You will have to give it time to get some data then. Here are graphs of two inputs that were created on the 12 of this month. At first the looked like the one you posted. These are inputs from my KH Carer imported by the Hydros. I am using these inputs and a new XD to dose All For Reef and KH buffer using dynamic dosing on the Hydros. I don't work for CoralVue. I am a user with a lot of experience with the controllers. I have some inputs that also have the frown face look. I will pass it along to them though,
1 day later: the graphs still have wrong dates and show no data. I'm suspecting this is a firmware/software bug. Don't know if it's related to the fact that this Wave Engine is not in a collective.
I've added a few other inputs with various other configs (different 0-10v pin, as flow meters, as alk sensors, etc)... all show the wrong date and no data.
You can create a collective of one using the wave engine if it is a WEv1 wave engine. The original and LE cannot be a wifi master which would be required so you cannot do it with them.
Sorry, do you mean you can with WE v2? This is a v1 (original?) wave engine, thus no wifi master and no possibility of it being a one-man collective.
It has to be a WEv2 since it has a updated processor. The original cannot. So it might be that the original WE will not do what you want as a stand alone device. It may have to be in a collective with another controller. Those were out before the Hydros controllers were around.
@Danny Carlos confirmed what you hypothesized, v1 Wave Engine gets no love:
"The WaveEngine v1 cannot do graphs. This is because it does not have the hardware to create the graphs you need. However, you can bring it into a collective where the master would pull the data from the WE and then graph it. WaveEngine V2 does have that capability."
Yep, forgot about that... no memory card in the WEv1 (or WELE i think too). Graph data is stored locally there.
