Dosing container volume issue with Sole
mhreefer
USA
Not sure if I posted this here or not.
I am running the Sole in the negative direction, left to right. It doses perfectly fine, and I have no issues with that. The issue is that it is actually adding to my dosing container volume with each dose.
Anyone else run into this?
It will do that if you run it backwards since the dose is counted as a negative dose instead of a positive dose. You can always switch the two tubes on the dosing head and then run it in the normal direction.
