Dual Inline TDS Sensor not working, staying connected
rballjunkie
Houston
I've had this for a few weeks. Cannot get it to read consistently and to stay on. It sometimes provides one of the two TDS readings and only shows 0 PPM for the other. I tested my RODI and it's not 0 ppm. It will stay on for a while, then disconnect itself. I have tried to connect to a different sense port, still does not work.
Is Screen Shot 2021-10-23 at 8.36.23 PM.pnganyone else having this issue?
That sensor only comes on once an hour for a reading if I remember correctly. The secondary reading will not graph. Only the primary reading. This one should be on the DI output and should read 0 TDS unless your DI stage is depleted.
