Dynamic Dosing Input Low/High Point
thom_smith
Albany, NY
Tried adding a Dynamic Dosing Regimen schedule to make corrections with magnesium. Quickly realized the maximum value of both Low and High Inputs is 1000 and magnesium target levels are well above 1000. Any reason why this max threshold can not be increased? Also out of curiosity, when and why would a negative range be used?
We need to make adjustments for that. So, for example, if you are using a Nitrate reactor, you would need to measure ORP in the negative range.
Would 2000 be sufficient on the high-end?
As far as I'm concerned, anything over 1350. 1500 or 2000 sound like good round numbers.
