Feeder
wowdude11
ca
Hello set up my feeder yesterday and have two questions. I have my feeder set to first feeding 10:00:00. What I’m confused about is feeding internal default is set to 2:00:00 does this mean it will feed again at 2am or that it will feed again in 2 hours?
second thing on my return pump i set up dependency mode on with it relying on “feeder”. I set the Dependency mode to “off if on”. I’m hoping this turns off the return pump at 10:00:am when the feeder is turn on. Minimum off time i set to to 00:10:00. So I’m hoping that means turn off for a minimum of 10 min so my fish can eat. If someone can tell me if this correct
This is my feeder setup. It has the first feeding at 10am like yours. The feeding interval is set for 4 hours. That is how ofter it will drop food. The number of feedings is set for 3. So it feeds three times every 4 hours starting at 10am. I only have it set to rotate once per feeding. If you set your return pump depends on to the feeder it should go off when the feeder comes on For 10 minutes. If you can be there to check it when it happens it would help determine if it is working the way you want it to.
Thank you. How would i set it up if I only want it to feed once.
Ok this is how i have it set up Now. hopefully it only feeds once a day.
