- Admin
- #1
Firmware 165 is now available and App 164 has been pushed through the App and Android stores.
Firmware 165 is now the public release version
If the mobile app has not updated yet, you can always access the latest version using the WEB APP at CoralVue HYDROS Web App.
Installation instructions:
December 19, 2020
IMPORTANT: This is ONLY for CONTROL units. It is NOT for WaveEngine or IceCap Controllers.
HYDROS Control - How to Update to the Latest Firmware
When the HYDROS app opens, you will be alerted if you need to download updates. After the update, your Control restarts. We recommend restarting the app.
www.coralvuehydros.com
December 19, 2020
- [FIXED] Min Time OFF does not work when changing modes
- [FIXED] Unable to modify OUTPUT if an INPUT it depends on was renamed
- [FIXED] Energy Consumption was reporting incorrectly. The decimal point was misplaced.
- [FIXED] Ability to create OUTPUTS without a name
- [FIXED] When collective is offline, no notifications were sent
- [FIXED] When triggering events with 0-10V INPUT, a gray screen flashed for a split second
- Completely revamped the way WiFi strips are paired and added to the HYDROS environment
- [FIXED] Max ON Time was not working correctly
- Reduced the frequency of the "Restart WiFi Device" message to only be shown when the WiFi strip needs restarting
- Changed default notification level from RED to ORANGE when adding a new WiFi Device
- Added "Return Pump" recipe with a leak sensor input option
- [FIXED] issue wherein collectives, the app does not display "Firmware Update Popup"
- Added Offset value to ORP
- Added filter to analog input graphs from showing isolated erratic readings when the control cannot reach the input sensor for a split second
- Removed temperature input option from ORP sensor
- Added ability to change the sensitivity to Rope Leak detector
- Added Offset value to the Temperature input
- [FIXED] issue with repeating triggers in Control
- [FIXED] Issue where an override would not propagate to a newly added collective member
- Added better automatic locking mechanism for storage cache
- Increased default rope leak sensitivity to 2V from 1V
- Reduced leak sensitivity on Return Pump recipe
- [FIXED] issue when triggering a 0-10V event, the app would flash a gray screen for a split second
- [FIXED] issue where different operating system font sizes would cause the app to display incorrectly
