- Admin
- #1
Firmware 177 is now available for the following devices:
Firmware 177 is now the public release version
As always, you can also control your devices using our CoralVue HYDROS Web App.
Installation instructions:
www.coralvuehydros.com
March 10, 2021:
- Control 4
- Control 2
- Control XS
IMPORTANT: If you have issues installing firmware 177 where you install the firmware but the unit reverts back to 165, then do the following: Tap on the "Install 177" button and then immediately kill/close the app. Wait 60 seconds and then return to the app and everything should be ok.
HYDROS Control - How to Update to the Latest Firmware
When the HYDROS app opens, you will be alerted if you need to download updates. After the update, your Control restarts. We recommend restarting the app.www.coralvuehydros.com
March 10, 2021:
- [FIXED] Max On Time on Generic OUTPUTS with more than one input did not work correctly
- [FIXED] Variable Light OUTPUT was not putting out variable voltage but instead just 0 or 10V
- [FIXED] Time of day handling on all HYDROS devices and collectives causing issues with graphs
- [FIXED] Generic OUTPUT no inputs would not follow schedule
- [FIXED] Graphing issue on HYDROS devices and collectives
- [FIXED] Devices would randomly reboot
- [FIXED] App ignores larger OS font sizes since the app already has large font
- [FIXED] Copy on WiFi Strip connection to make it a bit more clear
- [FIXED] Adding and/or renaming some HYDROS devices caused others to reboot
- [FIXED] When renaming some HYDROS devices, OUTPUTS did not update name and location
- [FIXED] When using landscape, some copy and buttons were pushed off the screen
- [FIXED] In some OUTPUT instances, the minimum range number could be set to greater than the maximum range number
- [FIXED] Issue when a Generic had 0 inputs
- [FIXED] HYDROS devices cannot have the same name as WiFi Strips
- [FIXED] OUTPUTS sorted by OUTPUT name
- [FIXED] When downloading firmware updates, it would cause INPUTS and OUTPUTS to randomly flash red
- [FIXED] Renaming a device a second time would cause a collective to show a mismatch
- [FIXED] When max time ON is reached and an audible alarm was enabled and selected, not all devices in the Collective would sound the alarm
- [FIXED] Repeating Schedule did not go past midnight
- [FIXED] Large configurations caused uploads to time out and fail
- [FIXED] Issue where purple reset did not wipe config file from SD card
- Considerably increased upload configuration speed
- Considerably reduced bootup time on HYDROS Control devices
- Added ability to input negative (-) and decimal values to 0-10V Analog INPUTS
- Added 0-10V Port location in the OPTIONS page to trigger modes on collectives by using 0-10V INPUT
- Added filters to prevent WaveEngine from interfering with Control Temperature probe
