Firmware 179 Release Candidate #2
Carlos
Administrator
Staff member
HYDROS Lab
Firmware 179002 is now available as a "Release Candidate #2" version for the following devices:
  • Control 4
  • Control 2
Firmware 179002 DOES NOT apply to WaveEngine and IceCap Controller.
IMPORTANT: If you have issues installing firmware 179002 where you install the firmware but the unit reverts back to previous, then do the following: Tap on the "Install 179" button and then immediately kill/close the app. Wait 60 seconds and then return to the app and everything should be ok.
As always, you can also control your devices using our CoralVue HYDROS Web App.
What is Release Candidate?
Release Candidate (RC) is the build released to check if any problems have gone undetected into the code during the previous development period. In most cases, there are no differences between the final build and the last release candidate.
Release Candidate is NOT the same as Final version. If you install a Release Candidate version, the app will warn you, "Firmware update available. The firmware in this unit does not match the current release," which is normal. Just cancel and continue normal use of the device. Once the Release Candidate version is marked as Final Version, the app will cease notifying you.
How To Install Release Candidate Firmware Version
  1. Open the status screen of your device or collective.
  2. Tap on the three horizontal dots on the UPPER right-hand corner and select "Device Properties."
  3. Scroll down and tap on "Update Firmware."
  4. Under each device, tap on "Load Experimental Version" and type 179002 to download.
  5. Once downloaded, tap on "Install 179002."
  6. The unit will restart.
Changelog March 29, 2021:
  • [FIXED] WiFi Strip Linking Issue
  • [FIXED] Incorrect voltage reported on Drive Ports
