Firmware 356 / App 3.2.0 (317)
  • Thread starter Thread starter Carlos
Carlos
Administrator
Staff member
HYDROS Lab
New firmware and App are now available.
The firmware is compatible with all HYDROS Controllers, including the IceCap WiFi Controller.
IMPORTANT:
  • NEVER, EVER, EVER update your firmware if you are not in the same location as your controller.
  • CHECK YOUR OVERRIDES! After a firmware update, always check your inputs, outputs, schedules, and overrides.
  • If everything looks good, please upload the changes after updating the firmware.
You can also control your devices using our CoralVue HYDROS Web App. (Clear your browser's cache and refresh so the app updates to the latest version.)
Installation Instructions:
Step 1: Download the new version of the app from your app store
Step 2: Download and install the latest firmware version. You must download the latest App version before updating to the newest firmware version.
Please visit the CoralVueHYDROS.com website for more in-depth instructions on downloading and installing the new firmware.
Changelog:
  • [FEATURE] – Added emergency access when the internet is out (WiFi and mobile data).
  • [FEATURE] – Ability to change the time it takes for the cloud to send a notification after it can no longer detect a device.
  • [OPTIMIZATION] – Improved how collective devices report WiFi connectivity problems.
  • [OPTIMIZATION] – Improved the LED pattern on X4, X2, XD, XS, X3, and WaveEngine v1/v2/LE to better display WiFi connection status and alarms.
  • [FIXED] – Special characters in the name could cause pump calibration problems.
  • [FIXED] – Inability to reboot the master device in a collective setting.
  • [FIXED] – The Safe Graph Range only allows one decimal point input.
  • [FIXED] – On power-monitored outputs, power details disappear when the output is manually ON/OFF.
  • [FIXED] – Run in sequence does not work correctly on smart dosing pumps.
  • [FIXED] – The read-only mode allows mode changes in some remote circumstances.
  • [FIXED] – Changing mode LED colors does not work correctly.
  • [FIXED] – In some remote circumstances, a dosing regimen activates a smart doser even when it is manually off.
  • [FIXED] – Inability to change Dosing Pump’s Notification Level (Reservoir Low).
