ZebraPleco
Trying to get my head around setting this up with input, output, and schedule. Can someone check and see if I set this up correctly? I want my AWC-ATO pump (1) to act as an ato AND refill after water change drain, AWC sump pump-2 to act as water change drain pump, I want AWC once daily and of course ATO always on except during AWC. I have the following 2 sensors- black (high water mark)=sense port 3, blue (low water mark)= sense port 4, 2 pumps: Pump (1) is in aging barrel and will act as both ato AND refills sump after AWC drain. This is connected to drive port 1. Pump (2) is in the sump and will act as drain. This is connected to drive port 2. I’m letting the ATO program do both ato and sump refill. Generic program is draining sump. The schedule will be a AWC once daily.
Any help appreciated.
