What does the leak input do in regards to the return pump’s “family”?
I’d like the pump to turn off if the leak sensor is wet. I know I can do this if the family is changed to “generic”, but what does the leak input do if the family is “return pump”?
So you’re saying if you use the built-in Return Pump recipe, it’s already programmed to behave correctly in normal situations, like feed mode or alerts.
Even if it doesn’t explicitly ask you to choose a specific “state” (like ON/OFF logic), it’s assumed and handled internally.
