CayoHueso
What's the proper way to set the Low/High Point on an advanced output in the Hydros controller app?
I'm setting up my new Hydros controllers, the XP8 and X3. I'm running the latest firmware, 342. It appears that the firmware has updated the layout of the outputs page in the last few months. The page layout and output options don't match a video SaltwaterAquarium.com shot 3 months ago.
I'm trying to setup a few outputs that are reliant on inputs (Temp & pH) as safe guards. For instance, my Alk doser is a smart doser and I don't need the Hydros to control it (I don't have any automatic testing setup), but I'd like the Hydros to cut off power to the doser if pH goes above 8.4 as a safety feature.
Using this example I created a new Output > Family: "Advanced" > Type: "Generic" > Input Count: "1" > Input 1: "pH Probe" > Input 1pH Low/High Point: >>> here's where I'm not 100% sure what to do next... I'd like for the outlet to be on all the time, unless the pH is 8.4 or higher. So based on what I've seen in previous videos, it would seem intuitive that I set the "Low Point" to 8.39pH and the High Point to 8.4pH. And then set "Active when Input 1" to "pH Low".
It seems to me that set this way the output would always be powered when the pH is below 8.39 and off when the pH is 8.4 or above.
Is this correct?
I'd like to do something similar with my heater and lights. Allowing the devices own controllers to control them but having the Hydros as safety backup if temp gets above 82ºF that it would kill power to both outlets. In those instances I'm guessing it would be the same; "Low Point: 81.9º > High Point: 82º > Active when Input 1: Temp Low".
TIA!
Is this correct?
TIA!
