Hydros ATO kit
BAMatter
East coast
I’ll be using this ATO kit- had a question regarding the sensor. What is the actual distance between when the sensor will trip “wet” or “dry”? Is it the distance between the 2 sharp bump outs on the sensor, or is it the entire sensor top to bottom?
I don’t have a lot of space in my return section and if the difference is a lot my pump may spout bubbles into the tank until it fills it… just need to try to figure out baffle height in my sump.
Thanks.
It is the two sharp bumps. Keeps the pump chamber of the sump to a very tight level. In my Fiji sump, the ATO runs all of 10-11 seconds when it is triggered.
