BAMatter
I’ll be using this ATO kit- had a question regarding the sensor. What is the actual distance between when the sensor will trip “wet” or “dry”? Is it the distance between the 2 sharp bump outs on the sensor, or is it the entire sensor top to bottom?
I don’t have a lot of space in my return section and if the difference is a lot my pump may spout bubbles into the tank until it fills it… just need to try to figure out baffle height in my sump.
Thanks.
Thanks.
