Hydros dosing pump issue
Angelmissy10
Florida
Not sure of what I may be doing wrong..
Pump is putting out about 35ml in its one minute span..I am trying to does n0p0x at 2ml but nothing I do seems to work. A Manuel does puts out more than my 2ml set. Any help would be appreciated. Thank you
If it is a Hydros dosing pump that is 43ml per minute so 2ml is a really low dose to try and do on that pump. How much are you trying to dose in a 24hr period?
Since I'm just starting n0p0x I was gonna start slow @ 2ml per day with frequent testing to see what dosage I would need to maintain nutrient levels
If you are setup to check the amount try 4ml and 6ml to see if one of those is more accurate. If so you can set the schedule to run every 2 or 3 days. You can do that until you get a better idea of how much you need per day.
