Hydros DRIVE PORT feeder constant connection notifications
pblogic
USA
Hello everyone,
I have the new driveport feeder hooked up to the control X2 and it seems to be working just fine. When I pull up the app it's recognized, when I hit the feed button it feeds, it shows as communicating fine. However every 4 to 8 hours or so (I'd have to go back and look at the notifications) the X2 sends me a phone notification and app push that says it's not responding. I open it up and it IS responding. Anyone else getting this problem? Bug? firmware issue? bad feeder?
I don't see that you have an alert setup in that output. Are you sure you are not getting alerts for a previously setup output? If an alert is active and you delete the associated input or output you will continue to get the alerts since they are in the que and will remain there until you clear the que or reboot your wifi master if it is a collective.
