Hydros web app
I am unable to connect my power strip to WiFi. Is there anyone I can call for help I don’t see a phone number?
Here is the inline manual at the paring WIFI strips. HYDROS Control 4 - How to Pair WiFi Strip/Smart Outlet . Make sure you 5ghz band and 2.4ghz band on your router have a different name. If they are the same you will have issues like this. Like JRill said make sure the device you are using to pair the wifi strips is on the same router channel you trying to put the wifi strip on. That should be the same as the control unit.
My phone is connected to 5g. I believe we only have 5g network
The Hydros only works on 2.4 ghz so if you have the control unit set up then you must have a 2.4ghz channel. The issue is the wifi strips have to go on the same channel.
