I don't know for sure but I have an iPad with 10.3.4 and it will not work on it. The one I use has 15.0.2 and it works except safari does not work with the web app it works with edge on the same iPad. It did work on safari before updating to 15.0.1.
Yeh I found out the 10.0 won’t work but not sure how far back I can go. Looking at cheap iPads just to run the hydros and mobius for my tank. I had one with 15.0.2 on it but the lcd just went out
I have an iPad mini 2 running iOS 12.5.5 and Hydros App version 2.2.0 (209) firmware 192. The iPad is mounted by the hydros Control units at my tank. Works great!
Like Bruce K (post #5) I also have a similar setup i.e. 12.5.5 and the latest Hydros App and firmware. I have the Ipad mini mounted to the inside of one of the doors underneath the tank. It takes power from the USB output on the Power Bar.
