BAMatter
I’m in the planning stages while my peristaltic pump and new PH probe are being shipped to dosing kalk. I plan on dosing based off of current PH value, the pump will turn on at “x” PH and shut off at “y” PH. I want to have a secondary PH probe for redundancy, not to be able to turn on the pump but to shut it off if PH starts to read higher than desired. Is it a possibility to have 2 PH probes linked to the same output?
So:
PH probe 1 - turn on and off pump depending on PH
PH probe 2 - redundant monitoring and turn off same pump if needed
So:
