Kraken & Varios Pump
  • Thread starter Thread starter KenS
KenS
St. Louis
I believe I have the port setup correctly (a screenshot of the settings is attached) but I cannot get Kraken to power my skimmer pump. It is a Varios powering an octo INT 250. I have confirmed the power brick is 24 volt, I can get the pump to power up just fine with the power brick but I can't get it to power up using a kraken 24 volt Force Port abd a 24 volt adapter cable. In the photo you'll see the pump is powered on that's through the power brick. I am holding the 24 volt Force Port adapter cable in my hand, when I plug that into the Varios controller there is zero power to the skimmer pump. No lights on, nothing. Any advice on what to do next I'd really appreciate it.
Here is a picture of the Box the pump came in I thought I threw it away but I found it it is a Varios 4-S
Like a dumbass, I had the wrong output hooked up to Kraken. I switched and its working.
