K519
id like to know if i load an old archived version will that revert my ph probe calibration to previous settings. can i just load jan 20 archive and it will read like it did before.
i wanted to calibrate the probe because i purchased the controller used and the probe was dry and said never calibrated so i figured why not. Didnt realize i could have just checked reading in solution first to see how far off it was first. after calibrating 7 10 then 4 i checked ph in 7.0 packet and it reads 7.11 my tank ph reading dropped 0.2. its not a big deal but if i can id like to load old archive see what reading is in 7.0 fluid and depending which number is closer to 7 i can decide if i need to calibrate or not.
also 4.0 calibration was red 81.95%. Waited more then 2 min. So not sure if i somehow messed up the procedure.
rinsed probe in clean water put in packet
7.0 i waited alot longer because numbers were jumping orange -11.75mv
10.0 stabiilzed alot faster green 101.13%.
4.0 waited 3-4 min it got stuck at 81.95 for a while so i accepted that.
could also just be a older probe that will need replacing soon. 7.11 i dont think is that bad but im just curious what it was before i calibrated it.
thanks.
thanks.
