Powered down both WE and pump?Power down for 60 secs fixed it
That appears to be the case! These are my return pumps, and I like them otherwise. I'm running (2) Vectra M2 pumps now, the Reef Octopus Varios 4 are rated at only about half the flow rate. I want to make sure that I can set them up (through the Wave Engine) to a lesser flow, but not off, during feed cycle (like Mobius).I would first suggest testing the pumps by themselves (make one primary and the other secondary) and see if they work correctly. If they do not, then the issue is the downgrade. The pump might let you downgrade, but the legacy software might no longer work correctly with the rest of the new hardware inside the pump controller.
Got the answer to the slave master question from seeing the coralvue video on how to set them up. Anyone know where I can get one of these chips or a ETM controller these days?
Thanks,
Adam
