New to Hydros and I have the X4 Pro Pack.
I want to integrate the IM Helio Controller and its two 300 watt heaters to my Hydros system, but the logic is going over my head. I saw a previous post from 2022 about setting the Hydros up as a back up to the Helio by setting the turn on and turn off on the Hydros to be 3 degrees higher than the Helio settings. However, I can’t even turn on the Helio unless I have the outlet “On” on my XP8. This I’m afraid also eliminates the option of having the Hydros do the lifting for temp control. It would just constantly reset the Helio…
Would it make sense to have my Hydros settings be: “Turn on at 74” and “Turn off at 80”? Then I’ll set my Helio for 77 or 78?
My logic is that I need the Hydros outlet for the Helios to be powered on unless there is a failure… otherwise I can’t even get power to turn on the Helio. The Hydros would then be a safety measure if the tank heats up past 80 due to faulty heaters/Helio.
This was long winded but hopefully makes sense to someone!
