Need Help Creating New Mode
Jasontkd
Kansas
I am trying to set up a new mode or schedule that I can manually engage that would override my normal schedules similar to how feeding mode works.
I am wanting to create a mode (or something) where I can clean my powerheads in buckets of citric acid. So, I would want them to run, but only at 25% or so, and at a constant speed. With the new firmware (186), I am not sure how to do this.
Ideally I would create a mode with no timeout but I don't know if this would work. Would I be able to do this, or would l need to create new schedules or something?
This could be done previously but I’m not sure how to do it with the new schedules and modes. I’m trying to make a mode button that overrides the current gyres schedule and runs the pumps at 100% until i press the normal mode button. Thoughts?
Create a new Schedule that runs the pumps at 100% constant speed and make the schedule ACTIVE only in the mode you want. Make sure your regular schedules are NOT active on the special mode.
@Carlos if I only want reverse to work on one schedule (eg hurricane), is this correct? Enable reverse on the pumps and only enable it on that specific schedule (hurricane)?
Was it possible to program individual parts? I think it has already been calculated. So that there is no increased wear of some parts.
