John Neuzil
I have an X3 controlling my freshwater tank. I put in a pH probe and get a significantly higher reading than I should. Out of the tap our water is at 6.5. My tank through several other testing methods is 6.8 ish. The probe measures 7.8 ish. I tested the freshwater tank water with the system running my reef tank and get the same reading of 7.8. If I test my reef water with the freshwater system I get the correct reading, same as my reef. So the question is, is there something about the Hydros and pH in freshwater that I am missing? And yes the probe has been calibrated.
