RODI TDS creep auto-flush
afboundguy
MA
Unfortunately "child" outputs created from a "parent" preset output (like RODI, AWC and others) can't be used as a dependency for any other outputs which would make what I want to do super easy.
I have many normally open(N/I) and closed(N/C) from a DIY auto-flush setup before I switched to Hydros and I want to add an additional flush with those solenoids by having the N/O solenoid on the line that goes from membrane output to resin canisters and a N/C solenoid T'd off from that line into the main waste water line that when powered should block off flow from membranes to resin canisters to flush that super high TDS water into the waste line.
I want to do this for 1-2 minutes after the normal Hydros flush solenoid runs for 1 minute and I was thinking I could create a second RODI "parent" output and add the N/O and N/C solenoids that are on the same PSU to the flush "child" output and allow for advanced programming and have it run for a minimum of 3 minutes and use the same high and low water sensors so bit RODI "parent" outputs run at the same time so the TDS creep flush runs for 2 more minutes after the main 1 minute flush.
